Description: Assign object properties to individual column grid lines within the overall grid so that bubbles can function as an intelligent tag similar to a door tag or room tag.
How Used: This would allow grid lines to be tagged in various detail views in an appropriate location using a leader, get the information from the grid, and insure that all detail views clipped from plans also display the correct bubble information without QC coordination problems. It would also allow an override in an xref wherein the detail is typical and one may want the bubbles to display with no text. The inspiration for this wish list item came from a question posted by another user and a suggestion better than our current work-around. The link below may clarify the goal.
http://forums.augi.com/showthread.ph...370#post213370
Feature Affinity: Columns and Column Grids
Thank you,
PBR
