When I insert a jpeg file (engineering drawing) into Autocad Lt 2006 - I get a solid white thumbnail image of the file with the file name in black text. I want to trace over the drawing.
Thanks or any help
Thanks or any help
Russ, I am going to move this from the Raster Design Forum, to this one, as I believe it will be better served here. Thank you.Originally Posted by russ.91961
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
What proceduare are you using? You say, Insert, and I assume using 'Insert > Raster Image' from the pull-down menu?Originally Posted by russ.91961
I don't know if anything in this this thread will help, just a discussion of challenges inserting image into LT... ratio not correct.
Melanie Stone
@MistresDorkness
I copy and paste the image into AutoCAD LT 20006. When I right click properties on the image in acad LT it says it's a OLE object and does not show up in the image manager?
With LT can you insert raster images? as with Autocad 2006
From what I have read , LT does not have an image manager to insert images. How you are inserting the images, those images would then be considered an OLE object.
Thanks Richard, Sorry, Russ, I do support a couple of LT users here, but don't have it on my pc to test out, so sorry for any misinformation/goofy questions.Originally Posted by Richard.Lawrence
Melanie Stone
@MistresDorkness
Not a problem. I don't have any access to LT. I'm just going off what I figure out with AUGI help.Originally Posted by Wanderer
Russ.
If you have any access to a copy of FULL acad, use that to attach the image file using the image manager. Once attached, it can be manipulated in LT.
HiOriginally Posted by johnbogie
There is no need...
RE: Import / Insert / Embed image files
Have a good one, Mike
