Thread: Worksets - Error Updating Titleblock
    All AUGI, all the time dsw98's Avatar
    2005-02
    Salt Lake City, Ut
    621
    Talking Worksets - Error Updating Titleblock
    I have a project that has workshare enabled. I am trying to make minor adjustments to a titleblock that already existed inside this project. When I try to upload the updated titleblock into the project an error message comes up that says "This action has caused deletion of non-editable Workset ' Project Standards '. It gives me the option to "Make Element Editable" but when I click on the button nothing happens, and that some error box just keeps popping up. And it's not really deleting "Project Standards". Is there no way to fix this. I know that once a project is Workshare enabled it's stuck that way. Any suggestions?
    NavisWorks Moderator david.kingham's Avatar
    2004-07
    Fort Collins, CO
    1,329
    Default Re: Worksets - Error Updating Titleblock
    When the error comes up expand it and there should be an element id of the object that is causing the problem, write that down, then go to Tools > Element ID's > Select by id, input the number, this will select the element, then push delete, then try to reload the titleblock again. If this doesn't work try deleting the titleblock from the project browser first then reload it...if all else fails send it to support
    2005-02
    Salt Lake City, Ut
    621
    Talking Re: Worksets - Error Updating Titleblock
    That didn't work. Is there a way to completely unload a titleblock from the project like you can with unused families (purge).
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Yes, in the project browser, scroll down to families, find your title block family and delete. The only problem is when you want your new one you need someway to know where the origin was.
    the error your getting is odd. I would try to save your tblk as another name, load it in and swap it out.
    Scott D. Brown, AIA
    BECK
    2005-02
    Salt Lake City, Ut
    621
    Sweet that worked. But to back up a step I tried deleting it from my browser and I got that same error. But then did as you just suggested and it worked. Good thinking. Who do these computers think they are dealing with
  1. New Titleblock, but receiving an error (pics attached)
    By stykface in forum Revit MEP - General
    Last Post: 2009-10-13, 03:19 PM
  2. Memory error while updating link?
    By gsucci in forum 3ds Max - General
    Last Post: 2008-11-01, 03:56 PM
  3. Fields in Titleblock not updating
    By KansasCAD in forum AutoCAD Fields
    Last Post: 2008-01-09, 03:06 PM
  4. Updating Titleblock family takes eons?!
    By cstanley in forum Revit Architecture - General
    Last Post: 2007-05-03, 08:06 PM
  5. titleblock error
    By lmarkey73498 in forum Revit Architecture - General
    Last Post: 2005-01-13, 08:46 PM
