Results 1 to 8 of 8
Thread: Write a LISP routine to enhance the revcloud command
    2005-08
    5
    Default LISP routine to enhance the revcloud command
    I am trying to write a lisp routine to enhance the revcloud routine and make the clouds a different 'global width' based on whether metric or imperial is chosen. I am also prompting for a choice between 3 pre-set sizes (arc lengths), inserting a rev triangle, and putting everything on the correct layer automatically.
    It is working beautifully, except the revcloud command doesn't seem to be reacting the same way other commands do. Upon execution, the lisp routine keeps going even though the cloud is not finished. This causes errors when it gets to the 'entlast' type stuff to alter the appearance of the cloud which isn't complete.
    It would seem that I need to find out what internally 'triggers' the end of the revcloud routine and causes the verbage "Revision cloud finished." to print on the screen. I'm sure it is checking for a matching start and endpoint, but I have no idea what variables it could be using. If I knew that, I think I could set up a loop checking for that condition to delay the start of the rest of the routine. Anyone know how to access that programming?
    Any thoughts??
    Melissa
    13,656
    Default Re: Write a LISP routine to enhance the revcloud command
    Hi Melissa
    Please note I have *split* this post into its own thread from thread "Nov '05 - TIPniques: How Things Stack Up ( found in the Hot News forum ).
    I have *moved* this newly created thread from the Hot News forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    2005-08
    1,043
    You can use this in your lisp, without seeing it, and it should work.
    (command "_.revcloud")
    (while (> (getvar "cmdactive") 1)
     (command pause)
    Tim
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,124
    Can you post what you have, so others may be able to see where you have been?
    13,656
    Quote Originally Posted by melissa.j.seidel
    Okay, I need help again! I couldn't figure out how to start a new RELEVANT thread...
    Hi Melissa
    Try the following...
    Most Frequently Asked Questions
    The AUGI Forums...
    Need Help with Forum Activities?
    Did you see the How to Forum article by our good friend and board member, Mike Perry in the last issue of AUGIWorld magazine? If not, be sure to download the issue and read it or get a pdf copy of it by clicking this link..
    AUGI Forum Guidelines
    User Maintenance
    General Forum Usage
    Reading and Posting Messages
    Hope the above helps,
    Mike
    Forum Moderator
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Check out pl2cloud as an alternative routine.
    http://forums.augi.com/showthread.ph...light=pl2cloud
    2005-08
    5
    Thanks CiphDRMRS!
    You wrote:
    Try this:
    (command pause)
    That didn't work initially, but when I replaced the > with and =, it worked beautifully! I am now debugging the rest of the routine(in my spare time). I will post the whole routine when complete.
    Thanks for your help!
    Melissa
    2005-08
    1,043
    Thanks CiphDRMRS!
    You wrote:
    Try this:
    (command pause)
    Melissa
    You're welcome. I'm glad you got past that part, and I hope that there isn't too much debugging you have to do.
    Tim
  1. Use Saveas Command from a Lisp Routine
    By CADdancer in forum AutoLISP
    Last Post: 2011-06-23, 03:01 PM
  2. LISP routine for Area Command
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-07-14, 06:24 PM
  3. Replies: 9
    Last Post: 2007-10-23, 12:34 PM
  4. enhance a routine to heal lines
    By clovis in forum AutoLISP
    Last Post: 2007-09-17, 05:11 PM
  5. BURST command in Lisp Routine
    By mhollar in forum AutoLISP
    Last Post: 2005-12-19, 11:08 PM
