Thread: Design options/option sets
    2004-06
    Memphis TN area
    7,048
    Default Design options/option sets
    I have a project with 2 design option sets and several options in each (one set for exterior, one for interiors). Is it possible to pick the primary option for only one set but still keep the options for the other set? When I clicked on the exterior option set and clicked on Accept Primary, it said it was going to delete the views associated with secondary options in BOTH option sets. This is not going to work. The client wants to have different interior layouts depending on the number of tenants, but has decided on an exterior scheme.... so what do I do?
    *edit* nevermind, the other interior views had some of the secondary exterior options set to display, so I had to change them all to display the primary exterior option to keep them from being deleted when accpeting the exterior option set.
    AUGI Addict Andre Baros's Avatar
    2003-12
    Point of no return
    1,611
    Default Re: Design options/option sets
    It should only apply to the option set that you currently have selected. The other option set is not effected.
  1. design option tree (dependent design sub options)
    Last Post: 2014-11-14, 04:26 AM
  2. 2014: Revit Design Option Sets
    By kellykate21 in forum Revit Architecture - General
    Last Post: 2014-10-07, 11:16 PM
  3. Design Option Sets - Room Bounding Elements - Non Primary
    By saeborne in forum Revit Architecture - General
    Last Post: 2009-09-24, 10:10 PM
  4. Design Options - "Remove From Design Option Set" Button
    By gmcguyre in forum Revit Structure - Wish List
    Last Post: 2009-09-16, 10:31 PM
  5. Design Options: Option Set the only way...?
    By ronjon in forum Revit Architecture - General
    Last Post: 2004-03-02, 05:03 PM
