Thread: Loose dynamic states from sub block after insertion into master block
    2005-11
    Exclamation Loose dynamic states from sub block after insertion into master block
    I've been assigned the tedious task of creating dynamic blocks for the company during slow hours. One of the many is all types of fastners. I've created dynamic blocks on each size of screw allowing the user to align and stretch to the appropriate length but my boss wants several blocks in one (Master Block) but each individual block ( Sub Block) has several versions of itself ( flat head, pan head, hex head, ect.). I tried puting all wood screws (# 2, # 3, # 4 ect.) in one dynamic block using visibilty however, I loose the origional dynamics (stretch, array, align) of the sub block after inserted into the master block.
    Any ideas on how to do this or even if its possiable?
    13,656
    Default Re: Loose dynamic states from sub block after insertion into master block
    Hi
    Please note I have *moved* this thread from the AutoCAD General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by ANRCREATIONS
    you can't nest visiblity states. You're going to be limited to: Wood screw (sizes), metal screw (sizes), etc. try playing with look-up tables, too.
    Sometimes, i get lost in my own thoughts and need to ask directions to find my way back.
    S&D DB Sharing Forum
    2005-11
    Thanks CNIBBE,
    I've dabbled a little with the look- up but no success as of yet. Thanks for your help.
    -Anrcreations
    Active Member mark.62793's Avatar
    2003-12
    Santa Rosa, California
    50
    Try posting what ya got. And we'll try and help you out.
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by mark.62793
    ^^ yeah, that too!!^^
  1. Dynamic Block Insertion lisp
    By LSElite in forum AutoLISP
    Last Post: 2012-11-28, 02:28 AM
  2. Dynamic Block and Insertion Point Help (Please)
    By DW2Whittle in forum VBA/COM Interop
    Last Post: 2009-01-29, 10:04 PM
  3. Linked Attributes, Dynamic Block Vis states
    By Chris.N in forum Dynamic Blocks - Technical
    Last Post: 2008-09-15, 10:13 PM
  4. LSP & Dynamic Block Visibility States
    By ReachAndre in forum AutoLISP
    Last Post: 2007-11-20, 09:32 AM
  5. Is there a way to see all Visibility states within a Dynamic Block
    By KansasCAD in forum Dynamic Blocks - Technical
    Last Post: 2006-04-17, 06:51 PM
