Results 1 to 7 of 7
Thread: Point (co-ordinate) filter not working as expected
    2005-01
    8
    Question Point (co-ordinate) filter not working as expected
    Good afternoon,
    I'm trying to use my point filter (ie. .x, .y, .z) but it is instead bringing up AutoCAD commands (explode, zoom). It is almost like it is not seeing the ".".
    Is there a toggle somewhere that I need to turn on in my profile?
    Cheers,
    Sarah-Jane Petti
    13,656
    Default Re: Point (co-ordinate) filter not working as expected
    Hi
    Is your OSnap menu missing OR just the Point Filters from the OSnap menu ?
    Have a good one, Mike
    13,656
    Hi
    Plus, see if the following couple of threads from the AutoCAD FAQ forum help...
    Mouse right click button playing you up
    Mouse middle button (wheel) playing you up
    2005-01
    8
    Post Re: Point (co-ordinate) filter not working as expected
    Quote Originally Posted by Mike.Perry
    Hi
    Hi Mike,
    None of the "right-click" mouse issues seemed relevant as I am actually using the command prompt. That leaves me with the info above.
    I do have my OSnap menu that I can look at, but I'm not sure where the "point filters" are on the menu. I don't see anything that seems to indicate co-ordinate or point filter, or matches with the .x, .y, etc. commands.
    Could you tell me the tab / option that I am looking for (and thank you for helping a newbie!!)
    Sarah-Jane
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,082
    This is a screen shot of the point filters pop menu as is in 2006. This screen shot was taken during the point command.
    HTH
    2005-01
    8
    Smile Re: Point (co-ordinate) filter not working as expected
    OK, so I think I understand where I was going wrong.
    When I type .x (etc) I need to me in the midst of the command that is "requesting" me to select a point. For example, if I type .x before I start the circle command, it will default to explode. If I start the circle command and it asks for the centre location, using the .x should properly allow me to select my centre based on an existing x co-ordinate.
    Thanks for your help. You can be sure that I'll post again if I have any continued problems.
    Sarah-Jane
    aka "the newbie"
    2002-01
    jUSt Here (a lot)
    9,082
    Quote Originally Posted by sarahjane
    Sarah-Jane
    aka "the newbie"
    We were all new once. Come on back when you need something else, and welcome to the forums.
  1. 2012: -PAN with coordinate entry not working as expected
    By Steve_Bennett in forum AutoCAD General
    Last Post: 2014-06-19, 07:11 PM
  2. 2014: Floors and view filter not working as expected
    By david_peterson in forum Revit Architecture - General
    Last Post: 2014-05-06, 03:52 PM
  3. 2013 Boolean subtract not working as expected
    By skyeg3206316 in forum 3ds Max - General
    Last Post: 2014-03-31, 07:44 AM
  4. Polar Stretch not working as expected
    By judekw in forum Dynamic Blocks - Technical
    Last Post: 2006-11-21, 09:53 PM
