Results 1 to 9 of 9
Thread: Error Message - Revit or system?
    I could stop if I wanted to ita's Avatar
    2003-09
    Perth Australia
    365
    Default Error Message - Revit or system?
    After changing the video card to a ATI FireGL V3100, I have started getting this error message. Clicking Ok turns of the view window, but other view windows are accessible. Opening a plan view gets a repeat of the message. An elevation or 3D view enables the file to continue.
    After an initial burst of activity, the error message disappeared for a while and I thought it might have been something in the files related to a particular response of the card. It has returned and is worse than when it first appeared. It is Revit related as it does not appear in any other app - graphics or otherwise.
    Has anyone else had this response and if yes, was there a solution to the problem? Thanks for any assistance on this!
    Active Member Solomon's Avatar
    2003-05
    60
    Default Re: Error Message - Revit or system?
    I've seen it happen with my PNY FX500 when I had OpenGL turned on and had about 15 views open. It seems there's a limit to how many views one can have open when OpenGL is turned on...
    HTH
    Solomon
    2003-09
    Perth Australia
    365
    Solomon, thanks for the confirmation - it is even happening with 3 or 4 views open - and those are not 3D or camera views. Thanks.
    All AUGI, all the time Elmo's Avatar
    2005-04
    South Africa
    959
    This might seem rude but could you post the specs of your PC here as well. It will allow a better idea of what might be going wrong.
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    Quote Originally Posted by ita
    Hi Ita,
    yep I've had that error message appeared from time to time. I initially contact Karel*CAD for support & they suggest to download the new build... did that! no more problems
    HTH
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Yes, as other have noted, when a lot of views are open. "Close Hidden Windows..." does the trick - until the next time. Pretty sure it's Revit not playing well with others (Dell Quadro FX500 video card). Newest build (20051017) didn't fix it for me - actually, it's been getting worse.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    This error message has been around for a long time. I've probably had it over hundred times since i've been using revit. And is usually and issue with the open gl video driver settings. Latest drivers are usually the best solution, or checking for the latest build, or as a last resort disabling open gl or overlay planes or both...
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    2003-09
    Perth Australia
    365
    Thank you all for the response. I have never seen that message before so I wasn't sure of its origin!
    I needed confirmation that it was Revit and the video card. Sounds a bit like . . . "Revit killed the video card" . . . sorry about that!!
    Set the card back to default settings but maintained the Revit setting (Has a Revit setting . . . how about that!) and all had been well. It was interesting to see that the overlay plane setting was not OK from initial installation. Never been able to get that setting working.
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    We were also getting that message on our system Dell Quadro 2MX 64. I talked to support who told me to reinstall the original Dell drivers, upgrade those to the latest Dell drivers and not to use the Nvidia drivers as they do not fully support the Dell card.
    That made the problem so bad that I could not have more than 2 windows open at a time and got weird green lines across the view window.
    Updated to the latest Nvidia drivers and all is well. I still occasionally get the message, it seems to appear when switching from a 3d view to a 2d view when many windows are open in the background. I have learned to only use 3-5 windows at a time and almost never a problem.
  1. Error message when opening Revit 2011
    By MTristram in forum Revit Architecture - General
    Last Post: 2011-02-09, 02:00 PM
  2. Revit Fatal Error Message
    By mbeham in forum Revit Architecture - General
    Last Post: 2008-08-04, 11:52 PM
  3. Strange error message in Revit... what does it mean?
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2007-12-07, 06:41 AM
  4. Error message when trying to open up a revit 9.1 file
    By Nelsonnc24 in forum Revit Architecture - General
    Last Post: 2007-02-02, 07:15 AM
  5. Revit error message...?
    By aaronrumple in forum Revit Architecture - General
    Last Post: 2006-01-27, 01:50 AM
