We recently (yesterday) upgraded a project from 8.0 to 8.1. We are using build 20050914_0100. Now at times when we save to central we get “Runtime Error!”. Has anyone seen this before? Or have any ideas?
Thanks for you help.
Tim
Tim
Contact Support asap. I had this happen to a projkect where the file ended up being corrupt. Support was able to fix it - but turn around time was a week and in the meantime we had to move ahead with work on a backup file.
I think we might be in that same boat.
have a good day,
Tim
I just got this error message on my computer a few minutes ago - I'd never seen it before until you posted this morning.Originally Posted by tim.76721
I was getting a bunch of errors as described in this thread. So I closed everything down and restarted the computer. When I started Revit back up, I got the same error message as you. Weird! (Revit 8.1 20051017)
edit: I should mention that despite the error message, I just clicked OK and Revit seems to be running fine... knock on wood.
We had this problem recently until we were able to isolate it to a network speed issue.
The problem was resolved on a large revit model with worksets enabled. (250MB +/-)
We found that the machine was connect to the network at 100mb/sec and not 1GB/sec.
We were able to replicate the error with the machine and it was resolved once we connected it via a 1GB/sec data jack.
