Thread: arx 14 to 2006
    2005-09
    7
    Default arx 14 to 2006
    is there a way to take a .arx that was written for AutoCAD 14 and have it load in AutoCAD 2006?
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: arx 14 to 2006
    Maybe, maybe not.
    You can try to load it in the same way as in R14, if it fail it fails.
    If you are lucky you can run it as it was meant to be, but all ARX program will not work.
    If you have the source code you can rewrite/compile to ARX again.
    : ) Happy Computing !
    kennet
    13,656
    Quote Originally Posted by cwintermute
    Hi
    The R14 ARX file would at minimum need to be recompiled using the ObjectARX 2006 SDK kit.
    See this by Robert Bell.
    For general info concerning Object SDK refer to the following...
    ObjectARX Programming Tips via ManuSoft.
    ObjectARX via Autodesk Developer Center.
    Have a good one, Mike
  1. Working with LDT 2006 Contours in ADT 2006
    By skrasovsky in forum ACA General
    Last Post: 2007-02-24, 09:06 PM
  2. Content Highway 2006 - Pre announcement (Due Q1 2006)
    By Marek Brandstatter in forum Revit - R & D Lounge
    Last Post: 2007-01-02, 02:27 PM
  3. Replies: 1
    Last Post: 2006-11-21, 12:40 PM
  4. Replies: 1
    Last Post: 2006-05-14, 03:57 PM
