Picture: A part with some holes cut in it
Holes are located with respect to x and y from a corner of the part
Question: Is there a way to place the holes without having to generate an offset line
intersection or use the move command twice?
Have you tried the FROM command modifier?Originally Posted by rhall.72202
Move
pick "from" point
@x-increment, y-increment
An another older method would be to place your hole at that corner and then MOVE or COPY from (base point) to @x,y.
