Thread: placing ERSI data in autocad
    Default placing ERSI data in autocad
    I know how to import ERIS (arc view) data in my dwg, but how do you get the data to be visible to plot the dwg showing the data?
    I prefer not to manually copy and paste each one from OD properties.
    2003-11
    442
    Default Re: placing ERSI data in autocad
    I have a program called dxfauthor, it's free, that I use to create dxf files from ESRI shape files. I think it can place GIS attributes onto the drawing.
    On another note:
    Do you know of any other user forums dealing with arcview. I know ESRI has one but I don't like the format.
    100 Club jmeyer.186809's Avatar
    2008-06
    The Yay! (Bay Area, CA)
    131
    Quote Originally Posted by smorgan View Post
    are you talking about getting the object data to label itself......for example like showing the the parcel data with the APN's labeled on the drawing or something? if so thats easy. You setup a query in your task manager and create a expression that will label all your APN's or whatever you desire. Look up a tutorial on youtube if your confused. It's really very easy and very handy.
    2016-02
    Does anyone knows how to get ESRI Project Files(.mxd) to Map3D???
    Turlock, CA
    5,735
    Welcome to AUGI.
    Map doesn't read an mxd. It reads the data that the mxd points to. Do you have access to the data sources that the mxd uses?
    C:> ED WORKING....
  1. Replies: 0
    Last Post: 2014-12-01, 04:36 AM
  2. Placing power and data outlets efficiently
    By Andrew Williams in forum Revit MEP - General
    Last Post: 2012-09-13, 12:25 AM
  3. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
  4. How to Create Access table data to AutoCAD VBa Combo box data
    By avinash00002002 in forum VBA/COM Interop
    Last Post: 2006-06-20, 08:22 PM
  5. Replies: 3
    Last Post: 2005-10-24, 04:03 PM
