Thread: Tapered Threads for Shaft Generator
    Illinois
    38
    Default Tapered Threads for Shaft Generator
    Description: I would like to see Internal/External tapered pipe threads added to the shaft Generator.
    How Used: Our Rotors have Tapered Pipe threads on the ends. Currently we can draw all aspects of the Rotor via the Shaft Generator except the threaded end. We add the threads to the end of the rotor via "Standard Parts" but this causes issues when using the Shaft Generators view command (the tapered threads are not included).
    Feature Affinity: Shaft Generator
    2011-10
    Default Re: Tapered Threads for Shaft Generator
    Probably a bit late now, but I notice the ANSI library now has one tapered Pipe thread entry: ANSI B1.20.1. This is in Autocad Mechanical 2012
    best,
    Paul
  1. Horizontal Shaft
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2015-01-20, 04:06 PM
  2. Replies: 0
    Last Post: 2010-09-16, 02:08 PM
  3. ACAD Mechanical Shaft Generator
    By robotgrass in forum AutoCAD Mechanical - General
    Last Post: 2008-04-18, 09:05 PM
  4. Shaft Generator Dialog Box
    By dougsilvi in forum MDT - General
    Last Post: 2004-09-02, 01:18 PM
  5. Frustrated Shaft Generator Dialog Box
    By dougsilvi in forum AutoCAD Mechanical - General
    Last Post: 2004-08-23, 04:08 PM
