Results 1 to 6 of 6
Thread: copy rotate object multiple times
    2002-06
    3
    Question copy rotate object multiple times
    I often have to copy rotate an object about a common centre but to several different angles. I wish there was a single command to do this,.. like the copy command but with rotation instead of displacement.
    (Polar array does not help because it uses the same angle between items, and "Copy move rotate" only makes one copy each time.
    150700
    3,439
    Default Re: copy rotate object multiple times
    Quote Originally Posted by gary.betts
    Take a look at the express tools Move, Copy, Rotate (MOCORO)
    39
    Quote Originally Posted by BrenBren View Post
    I agree that MOCORO will do the job. But, I feel it is either too complicated, or there is not enough documentation to make it usable.
    2006-12
    We have a lisp routine for that
    2002-06
    3
    I have a lisp routine now
    (defun c:ro_cox (/ mysset base_pt ref_ang new_ang loop_sw )
    (Princ "select objects to rotate")
    (setq mysset (ssget))
    (setq base_pt (getpoint "\nselect basepoint"))
    (setq ref_ang (/ (* (getangle base_pt "\nselect reference angle") 180) pi))
    (setq loop_sw 1)
    (while (= loop_sw 1)
    (setq new_ang (getangle base_pt "\nselect new angle"))
    (if (boundp 'new_ang)
    (command "rotate" mysset "" base_pt "C" "R" ref_ang (/ (* new_ang 180) pi))
    (setq loop_sw 0)
    princ))
    Hi Gary,
    If you are using AutoCAD Mechanical (as I assume you are given that you have posted the request in this forum), you may want to check out the new Move/Copy/Rotate feature in AutoCAD Mechanical 2010 (just released).
    Shashikanth
  1. Replies: 13
    Last Post: 2014-01-20, 06:14 PM
  2. Multiple Option for Copy in Rotate Command
    Last Post: 2012-05-18, 11:55 AM
  3. Move, Copy, Rotate - Show the object insted of the outline
    By rmejia in forum Revit Architecture - Wish List
    Last Post: 2007-07-07, 02:17 AM
  4. Select an Object, then Copy and Rotate it 90 degrees
    By Randolphbordner in forum AutoCAD Customization
    Last Post: 2007-06-24, 10:36 PM
  5. Replies: 0
    Last Post: 2005-03-26, 04:55 PM
