Results 1 to 8 of 8
Thread: Hatch pattern becomes "scrambled"
    2005-11
    Default Hatch pattern becomes "scrambled"
    Hi,
    I'm a newbie to augi so be gentle. I've searched the forums and autodesk website for this but haven't seen anything. My problem is that sometimes when I hatch, the pattern gets "scrambled". Like I'll hatch with the gravel pattern and it will come out disconnected or broken looking. I Regen and nothing. This only occurs when I save a file from a read-only file and then try to hatch in the new file. The original file works fine.
    Any ideas? I can send screen shots if you want.
    Thanks,
    Geoff
    9,805
    Default Re: Hatch pattern becomes "scrambled"
    What version of what product are you using? Assuming 2006, since we are in that forum.
    If pre-2006, change the value of SNAPBASE to a location near the area you are hatching.
    If 2006, the "hatch origin" option is in the BHATCH dialog.
    More info: http://support.autodesk.com/Getdoc.asp?ID=TS60223
    13,656
    Hi
    Have a browse of the following thread in the AutoCAD FAQ forum...
    Hatch patterns playing you up
    Have a good one, Mike
    2004-10
    22
    Unhappy Re: Hatch pattern becomes "scrambled"
    I am having the same problem with Gravel and Concrete hatches.
    I have: reset MaxHatch to a lower value
    set snapbase close to the area to be hatched
    set limits to include all drawing entities
    It still doesn't work.
    Help, please.
    13,656
    Quote Originally Posted by patricia.ellistone
    Hi
    Try setting Maxhatch to a higher value.
    If that does not work, please post the problem drawing file so we can take a look...
    I could stop if I wanted to JASONM30395's Avatar
    2002-04
    Halifax NS Canada
    397
    I've also noticed that it the boundary you are hatching is in a different ucs this can (although not always) cause problems.
    Loyalty above all else except honor
    For my honor is my life!
    9,805
    Help, please.
    What AutoCAD version are you using?
    Member merliny2k_99's Avatar
    2002-05
    Tide Country
    4
    Talking Re: Hatch pattern becomes "scrambled"
    Quote Originally Posted by rkmcswain
    Thanks R.K. I did not pay attention that they changed from 2005. I just had the same issue with gravel pattern and SNAPBASE did not work.
  1. 2014: Need Hatch pattern for "Void Form"!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2015-02-04, 12:00 PM
  2. 2008: Hatch problems - "could not set hatch pattern"
    By htlmv in forum ACA General
    Last Post: 2012-12-05, 02:24 PM
  3. Replies: 0
  4. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
  5. Replies: 5
    Last Post: 2006-02-28, 01:20 PM
