Thread: Assigned color/material changes when placing component in model
    All AUGI, all the time AP23's Avatar
    2005-11
    530
    Default Assigned color/material changes when placing component in model
    When i make a new Family and place it in the model, the color changes. When I go back into the family editor, the component has the color i originally assigned it to. How is this possible?
    The left image is sample of a sliding door that is in the family editor. It has the correct assigned color/material. The right images is when i place it in the model. It has a complete different color. When i go back in to the family editor i get the left image.
    2002-02
    St. Louis, MO
    4,695
    Default Re: Assigned color/material changes when placing component in model
    If you assign a material such as "Wood" to an object in the family editor, and then import that into a project that already has "Wood" loaded (with a different color) - the project's settings will be used and override the family. So you would either need to change what wood looks like in the project - or make a "Wood2" in the family.
    A better solution is to make a material parameter in the family, then assign the objects material to this parameter. Leave the parameter set to the default of <By Category>. This way when you bring the object into the project, you can simply change it's material to any material you like. This makes the family much more flexible if it will be used in many different projects.
    2005-11
    530
    It took me a while to figure it out, because I dont really know the revit's jargon. The tutorials just show you how you can assign materials direct but not via the parameters route.
    I made new materials in the settings menu, then I added parameters in the family types dialogue box. Finally I selected the elements form the components that needed materials and selected the parameters under material in the elements properties.
    Wow, this really impressed me. With just one click of a button I can change the frame's and panel's color, each type can have a different material. Revit aint that bad after all.
  1. Move and Rotate Component when placing Assembly Components
    Last Post: 2019-11-18, 07:44 AM
  2. 2013: Placing lighting fixtures on a modeled in place component....?
    By xzibited377538 in forum Revit Architecture - General
    Last Post: 2013-05-15, 03:03 PM
  3. select by material assigned
    By steedlei in forum Revit Architecture - General
    Last Post: 2007-09-12, 01:15 PM
  4. Materials assigned to 3D Model do not Insert when Model is used as a Block
    By CharlotteDsgnr in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-03-23, 05:46 AM
  5. Hatch Assigned to Material/Custom Hatches
    By darrell.badger in forum Inventor Wish List
    Last Post: 2006-01-24, 02:24 PM
