Thread: Grass Texture map
    100 Club Gene Herring's Avatar
    2005-06
    103
    Default Grass Texture map
    Can anyone give a pointer on how to render grass with the 45 degree angle and alternating "mowing" rows effect. (see image sample) In either Accurender or Viz. Thanks.
    All AUGI, all the time janunson's Avatar
    2003-07
    Grand Rapids, MI
    650
    Default Re: Grass Texture map
    1. Use a texture map that includes the rows... some have been posted here.. here's some of mine.
    2. Rotate the orientation of the map in the material editor if it doesn't align to your model the way you'd like.
    "It is a besetting vice of democracies to substitute public opinion for law." (James Fenimore Cooper)
    ""Interesting. No, wait...that other thing. Tedious."
    --Bender on Futurama
    2003-09
    1,907
    To complete the question, in Viz you use the UVW mapping icon to orient the bitmap. Select planar mapping and then size your bitmap, then using the mapping icon, rotate the map orientation on the surface the way you want it to be. Once set, unselect the mapping icon and return to the model.
    2005-06
    103
    Great! Thanks guys.
  1. 2013: Grass asset- St. Augustine
    By thomas.denney836893 in forum Revit Architecture - General
    Last Post: 2013-05-31, 10:20 PM
  2. Grass-O-Matic
    By batproj in forum Français - 3ds Max / Maya
    Last Post: 2010-06-18, 07:56 PM
  3. Grass in the middle of Concrete
    By SwtFlwrGrl83 in forum Revit - Student Support
    Last Post: 2008-05-13, 05:41 PM
  4. Tutorial - Grass!
    By stusic in forum DV - Tutorials
    Last Post: 2007-08-14, 12:34 PM
  5. Who has some good grass???
    By twiceroadsfool in forum Revit - Rendering
    Last Post: 2006-02-08, 12:54 PM
