Results 1 to 6 of 6
Thread: aec_curvetext orientation
    2005-09
    112
    Default aec_curvetext orientation
    I am using Land Desktop 2005 and am having trouble when I am labeling curves. Basically when I label curves it creates aec_curvetext. I am not able to rotate or flip the text so that I can orientate it corrrectly. I have searched the Land Desktop forum and found others to have the same problem. Does anyone have a lisp routine that they currently use for this because I am sure it would be helpful not only to myself but to others on AUGI and if not does anyone have any ideas of how to go about this. Thank you
    2015-12
    Central Oregon
    591
    Default Re: aec_curvetext orientation
    Hi Chris, I have been unable to trick the CurveText into flipping. I have written a small routine that converts the CurveText to MText. This makes it easy to move/rotate but it's no longer aligned with the curve. If you would like it just let me know.
    Jeff
    2005-09
    112
    I haven't had any luck either so I guess it is back to the drawing board. Is this something that you also have a problem with?
    Member Capo De Capo's Avatar
    2002-08
    Newport News, VA
    21
    Quote Originally Posted by miff
    Jeff
    I would be very intersted in seeing this code, if you would share with me. I have same problem as viewport is not always twisted the same as the model orientation. Any help would be greatly appreciated. Thanks In Advance!
    2015-12
    Central Oregon
    591
    Here ya go!
    ;;Function to convert Curve Text created by LandDesktop labels into MTEXT objects
    ;;by Jeff Mishler August 2005
    (defun c:ctxt2mtxt (/ ang doc ent inspt mtxt obj space ss styl txt1 txt2)
      (if (not (setq ss (ssget ":S" '((0 . "AEC_CURVETEXT")))))
        (alert "You must select AEC_CURVETEXT to use this function!")
        (progn
          (setq ent (ssname ss 0)
    	    obj (vlax-ename->vla-object ent)
    	    ent (entget ent)
    	    doc (vla-get-activedocument (vlax-get-acad-object))
    	    space (if (= (getvar "cvport") 1)
    		    (vla-get-paperspace doc)
    		    (vla-get-modelspace doc)
    	    txt1 (vlax-get obj 'textabove)
    	    txt2 (vlax-get obj 'textbelow)
    	    styl (cdr (assoc 7 ent))
    	    inspt (cdr (assoc 11 ent))
    	    ang (cdr (assoc 54 ent))
          (setq mtxt (vlax-invoke space 'addmtext inspt 0 (strcat txt1 "\\P" txt2)))
          (vla-put-stylename mtxt styl)
          (vla-put-layer mtxt (vla-get-layer obj))
          (vla-put-height mtxt (cdr (assoc 40 ent)))
          (vla-put-rotation mtxt (- ang (/ pi 2)))
          (vla-put-attachmentpoint mtxt acAttachmentPointMiddleCenter)
          (vlax-put mtxt 'insertionpoint inspt)
          (vla-delete obj)
      (princ)
    2002-08
    Newport News, VA
    21
    Thanks a bunch Miff, I actually found this same code over on ADG, did you post that there too. LOL!
    Thanks again,
  1. 2011: Tag Orientation
    By huntbh in forum Revit Structure - General
    Last Post: 2012-05-04, 11:58 PM
  2. UCS Orientation
    By dan.spinella in forum AutoCAD 3D (2007 and above)
    Last Post: 2010-04-23, 02:51 PM
  3. dim orientation?
    By smdin79 in forum AutoCAD LT - General
    Last Post: 2005-04-19, 03:34 PM
