Thread: Double Menu Entries
    100 Club Aquaserpent's Avatar
    174
    Default Double Menu Entries
    Ok I just got back from AU and tried to modify my Menus like I saw in one of the demonstrations. Now I have File, Edit,View,...more than once on my Map 3D. How do I fix it?
    Well I'm not sure how I did it, but I have it fixed, I'm still a little confused, as to what menu I am editing through the CUI. I make changes and nothing happens, then when i insert a new menu the changes I made previously are there. Secondly where is this work space, I would like to have Civil and Land loadable through Map.
    2001-05
    Austin, TX USA
    2,201
    Default Re: Double Menu Entries
    You can customize a workspace to only show the menus you wanted. You can do a search in the forum to find more info on workspaces.
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,444
    Or you can check out Lynn's column at Cadalyst By checking out this article
    Taking CUI One Step Further - customizing CUI for mouse buttons, keyboard commands and functional keys in AutoCAD 2006, Lynn Allen, Cadalyst Management
    TN/KY Area
    1,640
    Quote Originally Posted by froose
    There's the problem.
    AU is meant to get out there and drink a few beers and party with the rest of the cad jockeys not to try and learn things. Tell him Mel.
    If you don't get the hang of the CUI from the other links posted I did a Powerpoint on it however I can't find it right now but the key points are:
    Menus items and toolbars make up a workspace,
    Workspaces make up the CUI - Map 3d and Map classic for example
    AutoCAD can have more than one CUI - the main CUI and particle's like Express tools and MAP are particle CUIs. Ask away if you have questions.
    Note: Only joking on the AU learning expericences it's well worth it.
  1. Double Click Pull Down Menu to Use Last Command Used from Menu
    Last Post: 2017-04-06, 01:09 PM
  2. Wanted: FAQ Entries!
    By mjdanowski in forum Revit MEP - General
    Last Post: 2010-06-24, 07:29 PM
  3. Entries Disappear
    By robert.1.hall72202 in forum AutoCAD Fields
    Last Post: 2008-08-28, 01:12 PM
  4. Order of menu entries in Enterprise CUI
    By ahandley in forum AutoCAD CUI Menus
    Last Post: 2008-06-13, 10:46 AM
  5. separate menu entries for single sheet vs batch printing
    By comhasse in forum Revit Architecture - Wish List
    Last Post: 2007-03-21, 01:04 PM
