Summary: The ability to save as previous versions when using the REFEDIT Command
Description: Have REFEDIT follow the current SaveAs version setting found in the OPTIONS dialog. There is currently no method to have REFEDIT save down to previous versions.
How Used: This would allow use of the REFEDIT command during migrations from one version of DWG to a newer version. Currently the only workaround is not to use REFEDIT during migrations, and edit xrefs through a normal OPEN.
Feature Affinity: Reference Edit
Submitted By: Kevin Busacker on September 27, 2005
