I have an over lapping hatch pattern at an arch cut thru a brick wall. Any one else have this problem? How Do I fix this? Zoom in to arch above front door.
Doug,
There could of a number of things happening here. My guess based on the PDF is there could be a one wall overlapping another wall of the same type or a plotting issue.
If it’s a plotting issue, I would try raster processing vs. vector in the print setup.
You might want to check that your hatch pattern is aligned in you front elevation view.
Thanks- I'll try these when I get back to the office... Have a great holiday!
