Thread: Option to scale or not scale text according to viewport
    ACAD Wish List Administration
    2005-06
    1,920
    Default Option to scale or not scale text according to viewport
    Summary: The ability to scale or not scale text according to the viewport scale.
    Description: To scale text globally to the veiwport scale.
    ie: I use text at paperspace sizes from 2.5mm standard to 7mm.
    General text is at 2.5mm, so when i draw in model space and the sheet scale is 1:50 the text in model space is to be drawn at 125mm height. When the scale is to be 1:100 the text in model space is to be drawn at 250 to get the same paperspace size of 2.5mm.
    We need a variable to be able to switch on & off the option to scale text according to the viewport.
    This way when required for the right application and job situation you can set the text to scale with the viewport.
    How Used: When i am drawing workshop drawing of Air Conditioning as i do, i switch the variable on.
    From here i draw all my text to the size i wish.
    Now if i draw at 1:50 and the project manager or the client wants the scale changed the text changes accordingly and all i do is simply rescale the viewport.
    Feature Affinity: MText
    Submitted By: Stephen J Coff on November 27, 2005
    2011-08
    4,581
    Exclamation Re: Option to scale or not scale text according to viewport
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. match annotation scale to viewport scale
    By Mary_Ellen_Banning in forum AutoLISP
    Last Post: 2014-12-18, 03:20 AM
  2. Annotate Graphic Scale Block by Viewport scale
    By msmith.109036 in forum AutoCAD Customization
    Last Post: 2013-11-12, 05:58 PM
  3. Replies: 0
    Last Post: 2013-11-08, 05:29 PM
  4. Set Annotation Scale Equal to Viewport Scale
    By CADdancer in forum AutoLISP
    Last Post: 2009-10-09, 04:48 PM
  5. Replies: 0
    Last Post: 2006-11-28, 10:37 PM
