is there a way to trim a block? Maybe with express tools?
Do you mean lines within a block, without altering the block? No.Originally Posted by sherflor
What specific application do you have for trimming a block? Maybe someone can come up with a work around for you.
I had someone ask me this question and my answer was a no. I just wanted to make sure I was on the right track. Thanks anyway.
Hi
Please note I have *moved* this thread from the AutoCAD Customization forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
Thanks, Mike
Forum Moderator
Hi
Would _.XClip work for your needs?
Have a good one, Mike
If you want to trim a block to achieve hidden line removal, try the wipeout command.
Aled Taylor
If you have only one block existing in the drawing, can use "refedit". But keep in mind that if the same bloks are repeated in the drawing all will be redefined as the edited one.
