Thread: Disable Civil object data in map 2006
    Member jessebelcher's Avatar
    2005-11
    30 miles se of Dallas TX
    9
    Question Disable Civil object data in map 2006
    For what we are doing I have to have Map 2002 and 2006. But if I create drawing in 2006 it adds this civil data to the drawing and I get the warning when I open it up in 2002 or 2005 (this drawing was created with a newer version of Civil 3d. Allenties created by Civil 3d within the drawing are in a proxy state. Etc Etc Etc Etc) I am sure everyone has seen this but my question is can I just disable what ever it that is adding this Civil 3D stuff so I don’t get this error. Oh I should say that I know that AecExportToAutoCAD2004 dose the trick. But I want to stop it so I don’t have to type that in to get rid of this message. Thanks for any help I can get on this. I was at AU this year (first timer). Blew me away! I know now that I picked the right line of work.
    Athens TX
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,431
    Default Re: Disable Civil object data in map 2006
    Have you changed your Proxynotice variable to off ( or 0 ). Or, you could create a toolbar button to run the EXPORTTO2004 command. Or are you talking about a different notice?
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2005-11
    9
    Proxynotice variable to off ( or 0 ). I have not tried that but i will in the morning and post back to let you know. I am pretty sure we are talking about the same notice.Thanks
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. Disable Property Data Dialog during tag insertion
    By dzatto in forum ACA/AMEP Tips & Tricks
    Last Post: 2007-10-15, 04:38 AM
  3. Extracting Object Data from Map 3D 2006
    By tim.ashton in forum VBA/COM Interop
    Last Post: 2007-05-23, 02:28 PM
  4. Replies: 1
    Last Post: 2007-04-07, 12:39 PM
