Thread: Sample APIs on installation CD
    Member ebtrad's Avatar
    2004-12
    33
    Default Sample APIs on installation CD
    Has anybody used these samples "APIs" on the installation CD, if so what should be done other that editing the Revit.ini, do I need to compile, and create dll files.
    Thanks
    I could stop if I wanted to Danny Polkinhorn's Avatar
    2003-12
    San Francisco, CA
    448
    Default Re: Sample APIs on installation CD
    ET,
    Yes, you'll need to compile the samples on the CD.
    Copy the samples to your computer. Open the solution file with VS.NET and compile it. A BIN directory will be created in the same location as the solution file, and the DLL will be placed there. Edit the Revit.ini file to point to the DLL located there. Run the solution and it'll launch Revit for you. It should appear in the Tools > External Tools menu in Revit.
    2005-10
    You can also use Visual C# Express- a freebie from Microsoft instead of the full-blown Visual Studio.
    Andrew
    2003-12
    San Francisco, CA
    448
    Quote Originally Posted by ajhannell
    Note that the Express versions won't work with Revit 8.1. Support for VS 2005 and all it's variants will be included with Revit 9.
    See this thread for more info.
  1. CP218-3: AutoCAD APIs: The Right Tools for the Job
    Last Post: 2014-12-01, 01:48 AM
  2. DE401-4: Ask the Experts About Manufacturing APIs
    Last Post: 2013-05-05, 01:41 PM
  3. DE105-2: AutoCAD APIs: The Right Tools for the Job!
    Last Post: 2013-05-05, 01:40 PM
  4. I would like to move sample lines from one sample line group to another.
    Last Post: 2011-11-18, 04:55 PM
  5. Toggle all sample sources on/off for sample lines
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-10-06, 05:14 PM
