I know I know that title does not make sense. I need help, or even a gentle hint of the right direction.
I successfully made a Class in VB.Net and compiled a DLL that loaded with AutoCAD's Netload command (references to acdbmgd.dll and acmgd.dll):
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
<CommandMethod("HelloWorld")> _
Public Sub HelloWorld()
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
ed.WriteMessage("Hello World")
End Sub
End Class
In a seperate VB.Net project I used a Windows form to search our SQL database for standard drawings records - it compiles to an exe.
Now I want to merge the two and make a DLL that can be loaded by Acad's netload, making a command that will display the windows form.
I opened the project that includes the windows form and added a class similar to the one above except the command code inside the CommandMethod is:
dim Frm as New Form1
frm.show()
I just cant locate where to compile it to a DLL, so I can load it with Netload.
It's ok I can take it, tell me just how many things I did wrong.
Thx.
Kevin.
