Thread: Logitech 3D motion controlers
    2003-10
    Santa Barbara
    397
    Default
    I would like to see REVIT support logitechs 3D motion control devices like the "space ball" it allows you to rotate a ball with your left hand to control pan zoom & rotation while using the mouse with your right hand to select. It can also be used to define 3D animation paths. it is supported by autocad & 3dmax as well as most other cad applications
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    Default Re: Logitech 3D motion controlers
    This has been addresses before and is backwards. Software does not support mice, mice support software. Logitech needs to write a driver that works with Revit.
  1. Motion Sensor - Where's the M?
    By tbcprson in forum Revit MEP - General
    Last Post: 2010-05-19, 05:35 PM
  2. Show Motion
    By GirlForRevit in forum Revit Architecture - General
    Last Post: 2009-08-18, 09:20 PM
  3. 3D Motion Controller
    By twewercandk in forum Revit - Hardware & Operating Systems
    Last Post: 2007-01-03, 04:48 PM
  4. Repetitive Motion...
    By mwolfe in forum Hardware
    Last Post: 2004-12-10, 05:39 PM
