Results 1 to 6 of 6
Thread: Combine large number of 3D faces into a 3D Polygon Mesh
    2004-08
    Hartford, Michigan
    3,194
    Default Combine large number of 3D faces into a 3D Polygon Mesh
    I am using regular AutoCAD 2006, so I would assume this is the best place for the question.
    I have a large number of 3d faces that I would like to combine into one entity, a polygon mesh. The reason I want to combine them is I would like to apply an aerial photograph to the area for a rendered 3d model.
    13,656
    Default Re: Combine large number of 3D faces into a 3D Polygon Mesh
    Hi
    Please note I have *moved* this thread from the AutoCAD General forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    0,0,0 The Origin
    8,569
    It sounds like you want the 3dmesh command. You can create the new mesh vertices by snapping to the ENDpoints of the existing 3dfaces.
    John B
    2004-08
    Hartford, Michigan
    3,194
    yes, that sounds like what I need, but I have over 200 3d faces that I need to combine, AutoCAD doesn't have a command that combines 3d faces into a 3d mesh? Does Map 3d 2006 have that capability? I can try to see if I can use that program. Or should I attempt to write a lisp routine to accomplish what I am looking for?
    13,656
    Hi
    See if the following helps ( Please note, I have not tried it ie Tested the method documented to see if it will work for your particular case )...
    3DFACE to 3DMESH
    Have a good one, Mike
    2004-08
    Hartford, Michigan
    3,194
    Thanks Mike, that tip worked great,
    The only problem I have now is taking my aerial and applying it to the 3d mesh to some sort of a scale.
    My aerial resolution is 6 inch pixels and is 3000 feet by 3000 feet, any tips on how to create a material to scale to apply to the mesh for rendering purposes?
  1. trying to combine parameters into a part number
    By pjohnson.137155 in forum Revit Architecture - Families
    Last Post: 2010-02-08, 01:12 PM
  2. Civil 3D surface convertion to Maya polygon mesh?
    By eraska in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-04-08, 08:27 PM
  3. Replies: 1
    Last Post: 2007-12-14, 03:55 PM
  4. Join 3D Faces to a Mesh?
    By ultimateguruguy in forum Land Desktop - General
    Last Post: 2006-05-09, 06:14 PM
  5. Replies: 1
    Last Post: 2006-03-12, 06:51 PM
