Results 1 to 10 of 11
Thread: Revising HM door familiee
    I could stop if I wanted to david.metcalf's Avatar
    2004-01
    Hartford CT
    315
    Default Revising HM door familiee
    Hello All,
    I am attempting to reverse engineer these posted examples of doors with HM frames so that the fame height is variable from 2 4 and 6 inches can anyone tell my why this example is not working where I create a head height from the dimension and end up with constraints issues? I believe I need to set the constraints of the RO of the door. I can't quite pin that down.
    David
    2003-09
    1,907
    Default Re: Revising HM door familiee
    Attached is the corrected family. I used a formula to tie the r.o. to door plus head, and a parameter added to the glass in the frame with the glass extrusion in edit mode. Aslo, your door height was locked at 6'10 on the family.
    2004-01
    Hartford CT
    315
    Thanks Skisouth,
    I will take a look at this revised example. Is there a tutorial that details more in how to create doors? With all the instance parameters possible, it seems the basic tutorials and ATC course books are insufficient in creating more complex families, just image the possibilities with formulas!
    David
    I could stop if I wanted to The Sweg's Avatar
    2003-09
    Amish Country
    206
    David,
    Check out the last months archived ATP. Aaron put together a great course on doors. It made me re-think my approach to all my families.
    Choose not to be offended.
    2004-01
    Hartford CT
    315
    Derek,
    Can you please post a link the site where the training site you mentioned is?
    Thaks you,
    David
    2003-09
    Amish Country
    206
    David,
    Forgive my ignorance, but I'm not sure how to stick a hyperlink in the posts. However, if you go to the top of this page and click on 'Education' , then on 'AUGI Training Program', then you will see a link to the 'Archived ATP Courses'. You'll find it under November.
    See if this works. If so, yea for me! If not just read above.
    2004-06
    Memphis TN area
    7,047
    Some months ago I made several door families w/ hollow metal frames. The front and rear rabbets are adjustable, as are the side frame widths, top frame width, depth of the HM frame, and the inset distance from the face of wall to the face of the frame. I can post some of them from work tomorrow if you like.
    AERC, PLLC
    Hernando, Mississippi
    2003-09
    1,907
    Quote Originally Posted by david.metcalf
    Derek,
    Thaks you,
    David
    David, the link is here Scroll down to select the archived building a better door.
    2003-05
    North Texas
    105
    The download is not available. Aaron got 3 of the 8 segments finished before the course was archived, but I don't know if he is going to continue the segments. I certainly hope so!
    Michael Vaughn
    BWG Architecture
    2002-02
    St. Louis, MO
    4,695
    ..it will be. I'll be doing the next couple of segments this weekend.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
  1. 2014: revising shared parameters
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2014-02-18, 10:40 PM
  2. 2013: Revising Alignments
    By tim_newsome in forum AutoCAD Civil 3D - Alignments
    Last Post: 2012-11-15, 01:35 PM
  3. Revising a Family Template
    By sthedens in forum Revit Architecture - Families
    Last Post: 2009-11-09, 11:05 PM
  4. Revising 2009 Deployment
    By Ferroequine in forum NavisWorks - General
    Last Post: 2008-11-26, 01:36 AM
  5. Revising Linked File
    By Alex Page in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-08-14, 11:31 PM
