When I try and Plot a Dwg to PDF, I get a Memory Error.
I install the update patch that I received when sending the error report
and that did not help...
Also have memory issues plotting to my 1050C hp plotter as well.????
what program/driver are you using to create the pdf?Originally Posted by rhayes.99001
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
ADT 2005 - Using the Adobe PDF Converter - Windows System Driver - By Autodesk
The best way I've found to create a PDF file from a DWF file is by using Adobe Acrobat 4.0.
4.0 installs a system printer driver called "Adobe PDFWriter". It works fine.
As far as memory issues on your computer goes, I would check to make sure that your Windows Swap file is sufficient.
I have run into memory problems on our 1050C, but not too often. It usually happens when I try to plot a file that is around 30 Mb in size. I will get an "out of memory" error, but it still prints, how be it slowly. If you get the "out of memory" error, just leave the printer alone for a while (acutally could be quite some time) and it will eventually start printing.
The only way I can think of to fix the printer memory error is to max out the printer's memory - which I think is 64 Mb (I may be incorrect). We have our printer memory maxed out, and still get out of memory error messages.
Joe
Thanks Joe,
I am printing PDF's from Autocad DWG Files - wile in Autocad.
Is there a better driver then the windows one.???
HiOriginally Posted by rhayes.99001
The following thread offers one or two possible alternatives...
ACAD to PDF ?
Have a good one, Mike
I have also used CutePDF
Generally it works well, but I still am getting a Memory Error.
Sounds like a computer issue. What's your setup?
Hi,
I want to know ur system's memory status? Is that file is having images? i had encounter this problem earlier.. u can use bluebeam for easy pdf writing
Have a nice day
Sudhir
