Results 1 to 7 of 7
Thread: BURST command in Lisp Routine
    2005-12
    8
    Default BURST command in Lisp Routine
    Is this possible? If so, please tell me how. I am trying to write an AutoLISP routine to clean up architectural files so that we only need to type in "FLR" to do everything we need. Attached is my routine so far, please bare with me as it is my first attempt. Also, another issue I am having is that the leaders stay as leaders and do not take any property changes through the routine, any ideas? Thank you in advance!
    (defun c:flr ()
      (COMMAND "BURST" "ALL" "")
      (COMMAND "_EXPLODE" "ALL" "")
      (COMMAND "-layer" "m" "FLRPLN" "c" "8" "FLRPLN" "")
      (COMMAND "-LAYER" "S" "0" "")
      (COMMAND "chprop" "all" "" "LA" "FLRPLN" "C" "BYLAYER" "")
      (COMMAND "-layer" "t" "*" "")
      (COMMAND "-layer" "f" "FLRPLN" "")
      (COMMAND "ERASE" "ALL" "")
      (COMMAND "-purge" "all" "*" "N")
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    2005-08
    1,043
    Default Re: BURST command in Lisp Routine
    Burst is not a native Acad command, at least not int 2004. Try is as (c:burst), and see if that gets you going.
    Tim
    2005-12
    8
    Thank you for your reply. It would probably help to say that I am running ACAD 2006 and do realize that Burst is an express tool command and has its own lisp file. Is there a way to reference that command to make it part of my lisp routine? Has that type of thing been done before or do I just need to run the burst command separately and then the lisp routine? Thanks again.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by mhollar
    As Tim mentioned, you would need to include a set of parenthesis around the BURST command as well as the C:
    (c:burst)
    Doing this may work, it may not. Some lisp routines do not lend themselves to be included in other lisp routines.
    2005-08
    1,043
    To expand on what Richard said. I think you will need to open up the express tools lisp file, and find what calls it. Once you know that, you can load it in your lisp file, and then call it the way it needs to be called. I haven't looked at the code, so I don't know how to call it in another lisp routine (the parameters to pass to it). If you search here, or the web, you might find how someone has done it though.
    Tim
    2005-12
    8
    Thank you for your quick replies. I did edit the routine to the following and it did the burst command, I just needed to select all and enter. Thanks again.
    (defun c:flr ()
      (COMMAND "DRAWORDERCTL" "0" "")
      (c:burst)
    2005-08
    1,043
    Glad you got it to work. If you are going to do all that to a drawing, you may want to do and audit also. Just a suggestion.
    Tim
  1. Add layer command line to a lisp routine
    By BrianTFC in forum AutoLISP
    Last Post: 2012-02-02, 07:47 AM
  2. Use Saveas Command from a Lisp Routine
    By CADdancer in forum AutoLISP
    Last Post: 2011-06-23, 03:01 PM
  3. Using the Burst command with LISP ?
    By stephen.coff in forum AutoLISP
    Last Post: 2011-02-08, 04:20 PM
  4. LISP routine for Area Command
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-07-14, 06:24 PM
  5. Replies: 14
    Last Post: 2007-09-03, 08:01 PM
