Thread: Building Systems drawings show scrolling ARX error since using ScriptPro
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    343
    Default Building Systems drawings show scrolling ARX error since using ScriptPro
    I used Scriptpro to run a script to update a font, audit and purge. LOTS of drawings!!!
    Some drawings were created in Building Systems 2004. I'm using 2005 ACAD (NOT BS).
    Now all those Building Systems drawings are getting the scrolling ARX error that we got when we tried BS2005 (which happens because BS2005 is NOT downward compatible with BS 2004)
    I have opened, worked on and saved these same drawings before, with no issues, but not using Scriptpro.
    Doe anyone know what could be causing this problem NOW.
    13,656
    Default Re: Building Systems drawings show scrolling ARX error since using ScriptPro
    Hi Sue
    Please note I have *moved* this thread from the AutoCAD Customization forum to this one as I believe it would be better served here.
    Thanks, Mike
    Forum Moderator
    ps For people arriving to offer assistance / help, you might like to review this thread ( Redefine Open - automatically run a script upon opening a drawing ) first.
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    That ARX error is launched when the first drawing is opened that was saved by a session that either loaded the ABS enabler or was opened and saved by ABS2005. It doesn't mean that all your drawings are corrupt. Essentially, once you open a drawing that fires this error off, you must shut down your session of AutoCAD and relaunch AutoCAD. You might find that only one of those files was corrupted. As you search for the culprit, be sure to shut down and relaunch AutoCAD each time you encounter the ARX error.
    RLB
  1. Exporting to Building Systems
    By Griff in forum Revit Architecture - General
    Last Post: 2006-12-13, 06:08 PM
  2. Allow scrolling of commands from multiple drawings in same session
    Last Post: 2006-11-06, 09:24 PM
  3. Scrolling ARX Error BS2004
    By Mamma Jamma in forum AMEP General
    Last Post: 2006-08-03, 03:48 PM
  4. Revit Mechanical / Revit Building and Autodesk Building Systems
    By danielmapes in forum CAD Management - General
    Last Post: 2006-02-24, 01:19 AM
  5. Building Systems
    By sfaust in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-12-14, 10:52 PM
