Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: 3 Questions - Plot to entire sheet; Output to JPG; Draworder by Layers
    2005-12
    25
    Default 3 Questions - Plot to entire sheet; Output to JPG; Draworder by Layers
    Hi all, I'm very new here and have those questions.
    I have a floor plan drawing and I have 3 questions;
    1- When I print my drawing it only occupies 2/3 of the paper and
    consequently it's size appears small, how can I stretch it on the
    entire paper?
    2- How can I export the drawing as JPG picture with the same size in
    A4 PAPER.
    3- The drawing is in layers and u all know that, we can't arrange
    layers in AutoCAD so layer a is on top of layer b like in photo shop.
    My question is when I draw a rectangle over the lines, I need this
    rectangle to cover the lines beneath it directly without the need to
    make hatch the rectangle with white color?
    Thank u all in advance
    2005-12
    25
    Default Re: 3 Questions - Plot to entire sheet; Output to JPG; Draworder by Layers
    I just want to add that units are meters and decimals are 0.00.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,137
    Which version of AutoCAD are you using?
    The plotting issue depends on how you want to print. You can have the drawing scaled to fit the paper or you can have the drawing print at a set scale. (ie: 1:100)
    For the JPG issue, you will need to select the proper printer driver (PublishToWebJPG.pc3). Your system may be different.
    Your last issue, depending on your version, you could use a WIPEOUT to place a rectangle or other shape in an area that will hide stuff behind it. DRAWORDER is another command you may want to look into. If you have the Express Tools installed you can also do the DRAWORDER by color.
    HTH
    2005-12
    25
    Thank you very much for your reply, I'm using autocad 2006 full and I want to pring a floor plan on an A4 paper. I did try fit on the pring on page but still the drawing in the bottom corner of the page.
    Thank u again.
    2001-12
    St. Louis
    5,412
    Question Re: 3 Questions - Plot to entire sheet; Output to JPG; Draworder by Layers
    Quote Originally Posted by mmkamel
    Thank u again.
    here's a screenshot of the plot dialog box, as richard said, it will depend on whether or not you wish to plot to a certain scale, and we might need a bit more information to walk you through accomplishing that accurately.
    in the bottom 3rd of this dialog you'll want to pay attention to the plot area and plot scale... without seeing your drawing, I can't tell if plot area is important, I usually set mine to plot extents, unless there is something outside of my titleblock that I don't want to include or would throw me off of my desired scale.
    the way to pull your selection to fit the entire sheet would be to check 'Fit to Paper' under plot scale. you can also see in the greyed out boxes below that what factor that will show up as by doing that, this example wouldn't be something I could easily measure off of.
    did that help?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2005-12
    25
    Dear Wanderer, Opie
    I'm attaching the drwaing here. What I need is to plot this drawing in a4 paper so that the drwaing covers and centered the paper and then export it as a jpg image with same specifications so when users print the image it is the same like autocad.
    U can see what layouts in this drwaing, those the ones I tried.
    about this drwaing: it is a floor plan for hall that will host an exhibtion of medical equiment. each blue square represents a square meter. Exhibitors stand will be allocated on this floor plan and when I draw in exhibitor stand over the blue squares. The stand should appear without squared beneath it so the exhibitor can count the blue squres and see what area he occupies in the floor plan.
    Thank u very much for your help
    2005-12
    25
    Opie, I did try the command wipeout and it worked better than expect. You guys are treasure.
    Wanderer, I attached the drawing plz have a look and look at the layouts some times when I try to make viewports, it duplicates the drawing over it self!!
    Thank you very much indeed.
    2001-12
    St. Louis
    5,412
    Talking Re: 3 Questions - Plot to entire sheet; Output to JPG; Draworder by Layers
    glad opie's tip helped. I'll try to take a look at that drawing before I leave work today, but, if I can't get back to you, I'm sure someone else will. They're all kind and helpful like that.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2002-01
    jUSt Here (a lot)
    9,137
    I'm at home today, so I'll try to take a look tomorrow. ly I will be the only CAD tech in the office tomorrow, so no promises.
    Good Luck.
    2005-12
    25
    No problem when u have time just have look.
    Thanks.
  1. Draworder setting for layers
    Last Post: 2017-02-27, 05:02 PM
  2. Assign draworder to layers in advance?
    By sevenDeuce in forum AutoCAD General
    Last Post: 2008-01-31, 12:27 PM
  3. Replies: 2
    Last Post: 2007-07-29, 12:15 PM
  4. Plot Sheet Sample for Output
    By tdrewes in forum AutoCAD Plotting
    Last Post: 2004-09-28, 02:48 PM
