Results 1 to 7 of 7
Thread: A Lazy Susan Camera Object That Rotates About Placement Via Keyboard Keys Only
    2005-04
    93
    Default A Lazy Susan Camera Object That Rotates About Placement Via Keyboard Keys Only
    It would be really cool to have a Lazy Susan type camera object that you can
    place in a room that does not move in any direction (its position in the room is
    fixed and can not be modified by keyboard key) but instead it rotates about in
    a 360 degree direction based on the keyboard arrow keys (left right up and down).
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    Default Re: A Lazy Susan Camera Object That Rotates About Placement Via Keyboard Keys Only
    You may know this, but you can get that effect if you render a sperical panoramic view (.pan file) and then view it with a pan file viewer like imove.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    http://www.truevis.com/portfolio/terrace/pano.html
    shows 3 panoramic renderings viewed by a java applet. Thus your wish has been granted if you know how to do it.
    The applet is JsphereMini.
    Rename .pan to .jpg.
    2003-04
    Chino, CA
    4,756
    Would be cool to get the PAN files without rendering! Shaded or hidden line mode!
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    you can also place a camera in a room and use the "dynamically modify view" which has a "walkthrough" tab. while you're on this tab, shift-click and drag and it will let you do exactly what I think you want.
    HTH.
    2004-07
    Massachusetts, USA
    1,191
    Quote Originally Posted by sfaust
    Ah, good idea. That. combined with an AVI screen capture would make a quick presentation.
    Could do it with a 'walkthrough' export, too.
    2004-07
    Massachusetts, USA
    1,191
    Quote Originally Posted by Scott Davis
    I think I know how it would be done!
    Make multiple .jpg exports around the room and put them together with Autostich.
  1. Keyboard shortcuts that utilize the shift and control keys
    Last Post: 2012-03-05, 11:54 PM
  2. Keyboard Shortcut Keys
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-02-22, 01:34 PM
  3. Keyboard speed (quick keys) in AutoCAD 2007
    By andrewp in forum AutoCAD General
    Last Post: 2006-11-29, 07:55 PM
  4. AutoCAD 2006 Keyboard Shortcuts assigned to Function keys
    By YKBELL in forum AutoCAD CUI Menus
    Last Post: 2006-11-02, 04:42 PM
  5. Enter previous value via keyboard Up / Down arrow keys
    By fabio_projetos in forum AutoCAD General
    Last Post: 2006-06-15, 02:49 PM
