Thread: Object in which space in ActiveX method !
    Member rajat_bapi_mallick's Avatar
    2005-08
    Kolkata, INDIA
    40
    Talking Object in which space in ActiveX method !
    Hi !
    How do I know that an object is laying on "model space" or "paper space" in ActiveX method ?
    Rajat
    INDIA
    100 Club CADmium's Avatar
    2004-08
    Eberswalde, Germany, Europe
    128
    Default Re: Object in which space in ActiveX method !
    try for example this code:
    (defun GETOWNERSPACE (OBJ / OBJLAYOUT NAME OWNER)
      (if(and(setq OBJ(cond
                        ((=(type OBJ) 'VLA-OBJECT) OBJ)
                        ((=(type OBJ) 'Ename)(vlax-ename->vla-object OBJ))
             (not(vl-catch-all-error-p
                   (setq OWNER(vl-catch-all-apply
                                'vlax-invoke-method
                                 (list
                                   (vla-get-ActiveDocument(vlax-get-acad-object))
                                   'ObjectIdToObject
                                   (vla-get-ownerid OBJ)
             (setq NAME(vla-get-name OWNER))
         (if(not(vl-catch-all-error-p
                   (setq OBJLAYOUT(vl-catch-all-apply
                                    'vla-get-layout
                                     (list OWNER)
           (list NAME  "= LAYOUT" (vla-get-name OBJLAYOUT))
           (list NAME  "BLOCK")
    call : (GETOWNERSPACE (car(entsel)))
    you can also modify the returns..
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Quote Originally Posted by rajat_bapi_mallick
    Hi !
    Rajat
    INDIA
    Hi Rajat
    Or give this a try:
    (defun demo-tab-test	(obj / adoc check obj)
      (vl-load-com)
      (or adoc
          (setq adoc (vla-get-activedocument
      (and obj
           (not (vl-catch-all-error-p
    	      (setq check
    		     (vl-catch-all-apply
    		       (function (lambda ()
    				   (vla-get-taborder
    				     (vla-get-layout
    				       (vla-objectIdtoobject
    					 adoc
    					 (vla-get-ownerID obj)
      (if (zerop check)
        (alert "Model")
        (alert "Paper")
    ; CaLL :
    (demo-tab-test  (vlax-ename->vla-object
          (car (entsel
    	"\n >> Select object \n"))))
  1. ActiveX component can't create object
    By jkp in forum VBA/COM Interop
    Last Post: 2014-11-19, 08:50 PM
  2. get boundary using Activex method
    By rajat_bapi_mallick in forum AutoLISP
    Last Post: 2009-01-07, 12:24 PM
  3. Fix the VLISP/ActiveX object-management bug
    By sinc in forum API Wish List
    Last Post: 2004-09-21, 08:10 PM
  4. Purge a particular item by using ActiveX method
    By rajat126 in forum AutoLISP
    Last Post: 2004-06-19, 06:42 PM
  5. "AngleToReal" in ActiveX method
    Last Post: 2004-06-15, 01:01 PM
