Results 1 to 9 of 9
Thread: how to change the line style "spline" into another line style"pline"
    2003-03
    3
    Default how to change the line style "spline" into another line style"pline"
    i wanna change the "spline " into "pline" .
    my msn:larry_yellow@hotmail.com
    2003-03
    3
    Default Re: how to change the line style "spline" into another line style"pline"
    i wanna know the batch command.which can change a lot of spline into pline.
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Check the Help menu [F1] for PEDIT, and the Multiple selection.
    Member sicko's Avatar
    2005-10
    high altitude SICKness!
    14
    I believe Larry is working with "splines" not polylines. I'm looking for the same answer and I know I've seen it around here before. I'll post if I find it.
    edit:
    http://forums.augi.com/attachment.ph...chmentid=10974
    this will only create a polyline with straight segments though as, I assume, arc could not be made to equal the curves of a spline
    the search function becomes totally worthless when every link that comes up takes you to someone telling you to do a search and then pointing to the ones that they found which, in turn, link you to someone telling you to do a search and so on.
    2003-05
    5,153
    TO CHANGE A SPLINE INTO A POLYLINE
    Step 1: WBlock the Spline
    Step 2: Open the Spline dwg and Save it as an R12 dwg
    Step 3: Save the Spline as a DXF file
    Step 4: Insert the DXF into your new file
    Step 5: Explode the DXF
    Step 6: Pedit the segments as a Pline
    2005-10
    14
    Quote Originally Posted by beegee
    I tried this one but my logo turned into 30,000 lines from 23 splines
    2003-03
    3
    thank u all ,beegee,sicko,maverick.
    that's done.
    Earth
    9,830
    Quote Originally Posted by larry_yellow
    Grab SPL2PL.VLX from
    http://www.dotsoft.com/freestuff.htm
    R.K. McSwain | CAD Panacea |
    100 Club mfowler's Avatar
    2002-05
    Paradise
    120
    Quote Originally Posted by sicko
    edit:
    Thanks. This did the trick (good enough) for me.
  1. 2014: Can't change parameter from "Instance" to "Type" in template family
    By Pavlin in forum Revit MEP - Families
    Last Post: 2014-02-11, 11:52 AM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. Line Style - "No Print?"
    By saeborne in forum Revit Architecture - General
    Last Post: 2008-05-20, 02:38 PM
  4. Replies: 7
    Last Post: 2007-09-26, 08:53 PM
  5. Change DWG Plot Style from "stb" Style to "ctb" Color
    By andrewp in forum AutoCAD General
    Last Post: 2005-03-28, 05:31 PM
