Thread: Can't move geometry from point to coord
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    Default Can't move geometry from point to coord
    I used to use this several times a day, ever since 1987. I want to move a bunch of geometry to a real world coordinate. My first point may be an osnap point, the second point I want to type in, say 0,0.
    Autocad 2006 appears to have taken away the ability to do this. Why should I have to know the "displacement" first? It looks as if I now have to build geometry with a snap point at the desired location before I can move my existing geometry to that location. This is a tedious, time consuming, extra step.
    Any tips on how to do this quicker the "2006" way?
    Super Moderator rkmcswain's Avatar
    Earth
    9,746
    Default Re: Can't move geometry from point to coord
    Quote Originally Posted by CAD Chick
    Check out the DYNPICOORDS system variable.
    Also see http://discussion.autodesk.com/threa...hreadID=419183
    R.K. McSwain | CAD Panacea |
    2002-07
    Calgary, Canada
    397
    Quote Originally Posted by rkmcswain
    Thanks, daugi! You rock!
  1. 2015: Point 3D Geometry
    By Capn in forum AutoCAD Civil 3D - General
    Last Post: 2014-11-03, 07:01 PM
  2. How to scale geometry in drawing and move attributes? C#
    By szm.bordel352396 in forum Dot Net API
    Last Post: 2014-07-18, 04:35 PM
  3. Can you schedule end point coord's of beams in autocad?
    By claes.hodnett382067 in forum BIM Management - General
    Last Post: 2012-10-03, 08:00 PM
  4. 2012: How to SNAP to point on SPHERE for move/3D MOVE?
    By rick663901 in forum AutoCAD 3D (2007 and above)
    Last Post: 2012-09-19, 07:59 AM
  5. Alignment Geometry Point Labels
    By eckdahlrd in forum Civil 3D Wish List
    Last Post: 2006-02-15, 03:30 PM
