Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Help write a routine that will inverse a selection
  1. #11
    All AUGI, all the time CAB2k's Avatar
    2016-01
    Brandon, Florida
    687
    Default Re: Help write a routine that will inverse a selection
    brandi_eyes53
    Any luck with using the ssminus call to the lisp?
  2. #12
    2005-12
    17
    Opening an AutoCAD 2004 format file.
    Regenerating layout.
    Regenerating model.
    AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
    AutoCAD menu utilities loaded.*Cancel*
    Command:
    Viewport is view-locked. Switching to Paper space.
    Switching back to Model space.
    Command:
    Command:
    Command: VLIDE
    Selection set subtract loaded, Enter ss- to run.
    Command:
    Command: Specify opposite corner:
    Command:
    Command: SS-
    Select all items to be considered.
    Select objects: Specify opposite corner: 83 found
    Select objects:
    Selection set created use Previous to use.
    Command:
    .........In other words......
    WHOO HOOOOOOOO!!!!!!!!!
    OMG, it worked!!!!!
    You have no idea how much I am digging this CAB - YOU are the MAN!!!!!
    I can't wait to put this one to work. I will be way more pleased to do these drawings now that I have this tool.
    I have other ideas too, but I'll just be satified with this one for now (It was the only one I REALLY wanted - the rest are just cool ideas).
    I've had a long wait for this one - I'll just savor the moment for now.
    Just smile in the knowledge that I am having an honest to goodness party on this end.....I even made a louder than necessary cheer of happiness. Strange looks from other departments included and everything.
    THANKS CAB!!!!!!
  3. #13
    2016-01
    Brandon, Florida
    687
    Glad we finally got it worked out, enjoy.
  1. Replies: 9
    Last Post: 2007-10-23, 12:34 PM
  2. Replies: 52
    Last Post: 2007-09-27, 09:09 PM
  3. Replies: 7
    Last Post: 2006-08-18, 08:15 AM
  4. Write a LISP routine to enhance the revcloud command
    By melissa.j.seidel in forum AutoLISP
    Last Post: 2005-11-14, 06:08 PM
  5. Please HELP: Need "Inverse of a Matrix" routine
    By bradipos in forum AutoLISP
    Last Post: 2005-07-08, 02:40 PM
