Thread: Design Options Visibility "Automatic" v. "Pri
    2003-05
    East Walpole, MA
    893
    Default
    Anyone notice a difference between these two choices?
    Active Member LMSmith's Avatar
    2003-07
    Cambridge, MA
    67
    Default Re: Design Options Visibility "Automatic" v. "Pri
    Automatic will switch the display to show the current option that you are editing. Setting the override to primary will not allow the switch (i.e if you edit Option 2 it won't show Option 2). Setting the view to primary is often unnecessary because primary is what is displayed when you aren't editing any options.
    2003-05
    East Walpole, MA
    893
    Thus the term "Automatic." And, it's a pretty cool feature. I've found that people living in Massachusetts are especially bright. (I grew up here, so I'm obnoxiously brilliant).
  1. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  2. Design Options - "Remove From Design Option Set" Button
    By gmcguyre in forum Revit Structure - Wish List
    Last Post: 2009-09-16, 10:31 PM
  3. "Active only" - Design Options in 2010
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2009-05-07, 05:31 AM
  4. Change "Edit Option" button to "Finish Editing" while in the Design Option
    Last Post: 2009-02-01, 07:04 PM
  5. ENTIDADES EN ALIGNMENT COMO "FIXED", "FLOTING" y "FREE"
    By cadia in forum AutoCAD Civil 3D - General
    Last Post: 2009-02-01, 04:21 AM
