Thread: Rotate viewport
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default Rotate viewport
    I want to rotate my view port view so I see my model at 90 Degrees
    and have the model stay as is.
    How do I rotate the view port view.?
    I got it....
    To rotate a view using MVSETUP
    At the Command prompt, enter mvsetup.
    Enter a (Align).
    Enter r to rotate the view.
    Select the viewport with the view you want to rotate.
    Specify a base point for the rotation.
    Specify the rotation angle.
    The entire view rotates within the viewport
    2002-09
    Madison, WI
    5,685
    Default Re: Rotate viewport
    The other option is to use the _dview command from the layout tab with the viewport active (mspace), select the view, block or what ever, and use the TWist option. I just got done with a project where I needed to use this, and I loved it.
    2016-01
    Wilmington, DE
    88
    I use this all the time, but use an older (maybe easier or harder, depending on you)method. I draw moving the ucs to create elevations and sections looking at the plan, without shifting the plan. When in paper space, I click into the view I want to change, type ucs/enter/z/enter then pick a line left to right under the view I want, then type plan/enter/enter. Then I just adjust the scale. Seems very quick to me.
    2002-08
    THANK YOU.
    2005-06
    in the upper right corner
    3,388
    Quote Originally Posted by jblock View Post
    Yes me too, I wrote a lisp routine to create named views that can be recalled through the view port (similar to what you're talking about).
    See this thread for the routine and more discussion on the subject.
  1. Rotate Viewport
    By Spanky in forum AutoCAD General
    Last Post: 2009-04-22, 04:54 PM
  2. Rotate Viewport?
    By mrfrancisleung in forum AutoCAD General
    Last Post: 2008-07-21, 08:57 PM
  3. How do I rotate a viewport
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2006-12-18, 05:23 PM
  4. Rotate the viewport, rotate the MS content
    Last Post: 2006-07-12, 12:38 PM
