Thread: Sheet Set Eerror message "Sheet Set File Is Not Valid"
    2004-07
    Southern New Jersey
    2
    Question Sheet Set Eerror message "Sheet Set File Is Not Valid"
    Every time I attempt to open a Sheet Set I get an error message "Sheet Set File Is Not Valid". It only happens at one work station. I reloaded AutoCAD 2006 and I still get the same message. Can anyone help please.
    2001-12
    St. Louis
    5,407
    Question Re: Sheet Set Eerror message "Sheet Set File Is Not Valid"
    Quote Originally Posted by acortes24
    I'm going to move this from the 2006 General forum to this one, as I believe it will be better served here.
    Just wondering about the setup with your sheet set? Are you accessing files from a networked location? Is it possible that this station or login that you're using doesn't have read/write access to all of the necessary directories? was the sheet set created with 2006? and you've said it's being accessed by it... hmmm, I'm not really sure.
    Oh, looks like this has been brought up a few times on the autodesk discussion boards. I don't have time now to scan these for applicable scenarios, but, hopefully there's something useful there. Thanks.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2004-07
    Southern New Jersey
    2
    Default Re: Sheet Set Eerror message "Sheet Set File Is Not Valid"
    Yes, I am accessing files from a networked locations. Is there a read/write access just for sheet Sets? I can open DWG files at this station. The Sheet Sets are created in 2005 & 2006. When I attempt to create a new Sheet set I get the same message.
    Thank you you for your help. If you think of anything else let me know.
  1. 2012: error "drawing file is not valid"
    By fmorton318502 in forum AutoCAD General
    Last Post: 2013-10-07, 02:23 PM
  2. 2014: Trying to Auto update sheet number "X of X" without using Sheet Set
    By chrismckennato in forum AutoCAD LT - General
    Last Post: 2013-09-26, 02:40 AM
  3. "drawing file not valid"
    By eveofdestruction in forum AutoCAD General
    Last Post: 2009-09-17, 06:47 PM
  4. Replies: 5
    Last Post: 2009-08-18, 06:33 PM
  5. AutoCAD 2007 "Unable to create Sheet Set file"
    By jramos77 in forum AutoCAD Sheet Set Manager
    Last Post: 2008-05-29, 10:25 PM
