Thread: Can I make my own Linetype ?
    2005-08
    Default Can I make my own Linetype ?
    I am working with Auto CAD 2006, my prpblem is can I make my own line type ?
    150700
    3,439
    Default Re: Can I make my own Linetype ?
    Hi
    Please note I have *moved* this thread from the New Forum Users Forum to this one as I believe it would be better served here.
    Below snippet is from the small print on the Forum General page (also refer to attached image) -
    <snip>
    New to the Forums? This is the place to experiment with the posting editor and learn how to interact with our forums. Please experiment here with forum features and commands.
    </snip>
    13,656
    Hi
    For starters try the information found in the following thread...
    Custom Linetype
    Have a good one, Mike
    9,805
    Quote Originally Posted by mujeebpc
    Sure. Have you ever made one before?
    You might start by studying the syntax found in the customization guide [F1 key], then use the -LINETYPE command. This creates the linetype definition using the command line without leaving AutoCAD. Good if you know the syntax and only have to do one.
    If you have more than one to define, create a .LIN file using Notepad, or some other ASCII text editor.
    You could also use the MKLTYPE command (part of Express Tools)
    Complex linetypes can be a little tricky, especially if you are using shapes. Express Tools also includes a MKSHAPE command to help with this part. If you use text in a complex linetype, create a textstyle dedicated for this use, and set it's fixed text height to 0.
    Lastly, if you have a drawing that contains a linetype that you want to add to your collection, then pick up NEW-LIN.LSP and/or TO-LIN.LSP from http://www.turvill.com/t2/free_stuff/index.htm. These routines will create a LIN file from linetypes in any drawing.
    2006-01
    How do you make the *.lsp file run (work)??
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by dkaiser.103387
    Have you tried the appload command?
    Quote Originally Posted by AutoCAD Help
    Loads and unloads applications and defines which applications to load at startup
    You may also want to look at this thread (Running Lisp).
  1. Make Projected Linetype Changes Retain Associativity
    Last Post: 2009-10-25, 05:29 AM
  2. make linetype continuous
    By gingermick in forum AutoLISP
    Last Post: 2009-06-01, 10:54 PM
  3. How do I make a fence linetype for a site plan
    By Dave Lewis in forum Revit Architecture - General
    Last Post: 2007-04-09, 09:43 AM
  4. Help make a Railroad Track Linetype
    By chung.lam in forum AutoCAD Customization
    Last Post: 2006-06-05, 08:30 AM
  5. Make a custom blockwall linetype
    By Smokiibear in forum AutoCAD Customization
    Last Post: 2006-02-13, 10:10 PM
