Thread: Create a new profile, set current, close AutoCAD. Open AutoCAD <vanilla> profile set
    2001-09
    12
    Default Create a new profile, set current, close AutoCAD. Open AutoCAD <vanilla> profile set
    I have a quick question about the profile settings in 2006. I created a new profile, set it as current, close AutoCAD and reopened the application to find out the profile has switched back to the <<vanilla>> profile.
    Can anyone tell me what I am doing wrong?
    Thanks,
    Tony Nichols
    0,0,0 The Origin
    8,569
    Default Re: Create a new profile, set current, close AutoCAD. Open AutoCAD <vanilla> profile set
    You could check the value of Target in your shortcut.
    Mine says - "C:\Program Files\AutoCAD 2006\UserDataCache\".
    A switch similar to "\P <<vanilla>>" would have that effect.
    John B
    "You can't convince a believer of anything; for their belief is not based on evidence, it's based on a deep-seated need to believe." - Carl Sagan
    2001-09
    12
    John,
    Thanks for the hint. I did not have a profile switch set but I die dint that it was pointed to "crogram filesAutodeskAcadm 2006UserDataCache" which must be what is resetting the profile.
    I created a new shortcut to "Crogram filesAutodeskAcadm 2005acad.exe" and the problem when away.
    Must be a cache issue using the first shortcut which installed when Mechanical installed.
    Again thanks for tip that assisted in finding the solution.
    Tony
    13,656
    Hi Tony
    Please note I have *moved* this thread from the AutoCAD 2006 CUI Menus forum to this one...
    Why? - This is not an CUI issue / problem.
    Thanks, Mike
    Forum Moderator
  1. Create Design Profile from a Polyline/Object within a Profile View.
    Last Post: 2012-09-04, 08:22 PM
  2. 2011: My profile keeps resetting when I close AutoCAD
    By tmad101185 in forum AutoCAD General
    Last Post: 2011-03-15, 12:00 PM
  3. Replies: 6
    Last Post: 2007-01-08, 01:12 PM
  4. Load vanilla AutoCAD profile at startup
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2006-11-30, 09:42 PM
  5. Replies: 3
    Last Post: 2006-06-05, 10:45 PM
