Thread: ACAD maps contain some Dot Lines with thickness
    2005-10
    Default ACAD maps contain some Dot Lines with thickness
    i work with ACAD maps from many different companies, so i get a lot of maps with different settings, linetypes and such. I find that in some of the drawings the dot lines can be thickened, where as in others they cant. Is there a setting i am overlooking? I would really like to know how to be able to set these dot lines with thicknesses.
    13,656
    Default Re: ACAD maps contain some Dot Lines with thickness
    Hi
    Please note I have *moved* this thread from the ASK the BOD forum to this one...
    Thanks, Mike
    Forum Moderator
    13,656
    Hi
    First - Which autodesk product are you using ? If it is not AutoCAD I will move this thread to the correct Autodesk product forum.
    My first guess would be those Dot Lines with thickness are Polylines that have Widths set.
    Is it possible to post an example drawing file so we can take a look.
    Have a good one, Mike
    2004-08
    Iron Station, NC
    3,198
    My guess would be that what Mike guessed is correct for the lines that have widths and the ones that cant be changed are lines, not Polylines
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    It could be the other way around. Polyline width overrides lineweight, so changing the linewight will have no effect on a polyline with a specific width.
  1. Re: Acad lines (ACAD.LIN) in thematic maps
    By kiefer_isaac647225 in forum AutoCAD General
    Last Post: 2012-10-25, 03:33 AM
  2. Tiled material maps rendering with black lines
    By trunk_boy456811 in forum 3ds Max - General
    Last Post: 2012-05-25, 12:51 PM
  3. Acad lines (ACAD.LIN) in thematic maps
    By toddh in forum AutoCAD Map 3D - Wish List
    Last Post: 2010-05-04, 03:28 PM
  4. Surface lines on 3d Acad 2002
    By frogdog22000 in forum AutoCAD 3D (2006 or below)
    Last Post: 2009-02-13, 05:06 PM
  5. ACAD Materials Not Installed? Maps are there.
    By 3dway in forum AutoCAD General
    Last Post: 2008-11-20, 08:57 PM
