Thread: Copying tool palates to workstations from a Network tool catalog
    2005-08
    17
    Default Copying tool palates to workstations from a Network tool catalog
    Does anyone know how to add shared tool palates to individual workstations from a centrally located tool catalog without moving the shared palate out of the tool catalog using the i-drop symbol in ADT 2004?
    I was able to create the Tool catalog using the Design Center and add my local styles to it but everytime I try to idrop the new palate to a workstation, it moves it from the catalog instead of copying it?
    Any help would be appreciated - thanks!
    I could stop if I wanted to H.Hunter's Avatar
    2005-08
    Somewhere, but not here
    241
    Default Re: Copying tool palates to workstations from a Network tool catalog
    Quote Originally Posted by acommero
    I don't use ADT, but I'll assume that it works similary to ACAD in this case. Just add the network path to the Tool Palette section in OPTIONS. This should let you draw information from all listed locations. (I'm pretty sure this works for 2004...been a while since I used that version.)
    2005-08
    17
    Tried that - still couldn't find it. Apparantly the only way I read so far is to i-drop it to the local tool palate but it still moves the tools out of the network catalog.
    Thanks though.
  1. Custom Tool Pallets/Catalog
    By hulrich in forum AMEP General
    Last Post: 2013-01-07, 05:30 AM
  2. Design Tool Catalog not working
    By battishillb in forum Software
    Last Post: 2010-10-29, 03:06 PM
  3. Tool Catalog
    By markklucas in forum ACA General
    Last Post: 2010-06-16, 11:00 PM
  4. Put sub-assemblies into a Tool Palette or the Custom Tool Catalog?
    By justin.d.ehart in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-06-05, 03:52 PM
  5. Design Tool Catalog
    By czeber in forum ACA General
    Last Post: 2006-10-24, 02:55 AM
