Thread: Multiple Drawing Xref Detach
    2003-03
    137
    Default Multiple Drawing Xref Detach
    Is there a Lisp routine out there that will search through a series of drawings and detach one xreference? This would save us a ton of time. Otherwise we would have to open up each drawing one at a time. Thanks!
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Multiple Drawing Xref Detach
    Nope.
    But you can use this link to make a script file and batch run everything.
    : ) Happy Computing !
    kennet
    2012-06
    3
    Smile Re: Multiple Drawing Xref Detach
    Hi.. try uploading the tool I provided in autocad and go for "xd" command. Hope it will reduce manual steps for detaching Xref's.
    Thanks
    Bireshwar Mallick
    2009-11
    5,628
    Actually, you can simply iterate a directory of drawings using an ObjectDBX wrapper which iterates the ModelSpace Block Object for blocks that IsXref = :vlax-true, and use the Delete Method on the ExternalReference Object:
    http://entercad.ru/acadauto.en/index...nce_object.htm
    ** Edit - Just be sure to check for the ExternalReference's Layer Object being locked (= :vlax-true (vla-get-lock <oLayer>)), prior to invoking the Delete Method in order to avoid a potential error. Restore the lock prior to invoking the SaveAs Method on the DBX Document Object.
    ... Lemon squeezy.
  1. Replies: 1
    Last Post: 2012-06-06, 12:29 AM
  2. Xref overlay without detach
    By cadprog in forum Dot Net API
    Last Post: 2008-11-04, 08:46 AM
  3. Unable to detach a Xref
    By sherflor in forum AutoCAD General
    Last Post: 2006-03-09, 01:34 PM
  4. Prompt to detach xref if erased from drawing
    Last Post: 2006-02-14, 05:54 PM
  5. Cannot detach a xref
    By kleenhippie in forum AutoCAD General
    Last Post: 2005-08-24, 04:03 PM
