Thread: Remove inch symbol from dimensions
    2004-08
    69
    Default Remove inch symbol from dimensions
    Is there a way to dimension a drawing with the Primary Units set to "Architectural" and not have it put on the inch symbol? Example 1'-2" would show up looking like 1'-2 automatically without doing a text override.
    Active Member tsbykatherine60220's Avatar
    2004-05
    Milwaukee, Wisconsin
    62
    Default Re: Remove inch symbol from dimensions
    Quote Originally Posted by jsnow
    If this is something you need to do on a regular basis and you are using an shx font file you can easily copy the current shx font file and modify it to have the " mark show nothing. You can then specify this font file for use with your dimension style. The whole task shouldn't take more than an hour or 2....
    Hope that helps!
    Rick McElvain
    Arnold and O'Sheridan
  1. 2013: Beam Graphical Zero Inch Offset of Stick Symbol Location
    By jmcdonald436635 in forum Revit Structure - General
    Last Post: 2013-12-02, 07:50 PM
  2. Eliminate Inch Mark in Dimensions
    Last Post: 2011-12-05, 07:12 AM
  3. Show inch/Metric Dimensions for Unthreaded Holes
    Last Post: 2007-06-01, 05:29 AM
  4. Use Feet an Inch Dimensions
    Last Post: 2006-11-06, 03:19 AM
  5. Remove spaces around dashes in dimensions
    By david.kingham in forum Revit Architecture - Wish List
    Last Post: 2005-07-20, 07:23 PM
