Results 1 to 8 of 8
Thread: Outside Render Farm Services?
    2015-10
    90
    Default
    We are still considering getting a dual processor station of our own to do renderings but have not yet pulled the trigger. We do, however, have an urgent need to get some walk-throughs rendered and they take an exhorbitant amount of time.
    Does anyone know of a company that will produce renderings from Revit models?
    All AUGI, all the time mlgatzke's Avatar
    2003-05
    Ankeny, Iowa, USA
    761
    Default Re: Outside Render Farm Services?
    Can Revit models be farmed? I'm getting ready to buy 25 new dual-processor machines and link them in a farm for VIZ. However, I'd be ecstatic to link them for Revit too if someone can tell me how.
    2003-05
    5,153
    No, Accurender can't use a render farm.
    Viz/Max and others can.
    I could stop if I wanted to Kroke's Avatar
    2003-04
    Redmond, OR
    446
    the only thing you can do is segment the animation path and have several different machines doing separate frames (IE: machine 1 does frames 1-500, machine 2 does 501-1000, etc). Then combine them all together.
    I havn't done this personally, but I you'd want to use the same radiocity solution for each machine.
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    rumor is that Viz 2005 will have some way to deal with Revit models. We'll know at the end of April for sure when it is released, but it might prove a solution where you could open and render a Revit model in Viz, and then use your farm...
    I wanna farm... that's way cool man!
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    Just be careful you don't buy the farm.
    2003-04
    Chino, CA
    4,756
    Caution, really bad attempt at humor to follow.....
    Sing along!
    "Old McRevit had a farm,e-i-e-i-o, with a Viz render here and a Viz render there....."
    2003-04
    Redmond, OR
    446
    /smack! hehe
  1. Render Farm
    By mboyer in forum Hardware
    Last Post: 2011-06-09, 07:07 PM
  2. Navisworks Render Farm
    By cmealy in forum NavisWorks - General
    Last Post: 2010-01-05, 10:18 PM
  3. Max 2010 Does Not Work on Render Farm
    By ivan.weiss in forum 3ds Max - General
    Last Post: 2009-05-04, 09:29 PM
  4. Autocad Arch. Render Farm?
    By gbelous in forum CAD Management - General
    Last Post: 2008-06-09, 03:15 PM
