Thread: Turn Radius Software
    100 Club Kris.Keller's Avatar
    Rigby, Idaho
    106
    Question Turn Radius Software
    I am not sure if this is the place to ask this question. I want to know what turn radius software that people use. I use AutoTurn 4.2. It is limited in reverse maneuvers. What other packages are there?
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,429
    Default Re: Turn Radius Software
    Kris,
    Check out the upgrade version Autoturn 5.X has some improved reverse methods. You can define the path with a polyline and then run the animations forward and reverse.
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    Rigby, Idaho
    106
    Quote Originally Posted by MHultgren
    Kris,
    Mark,
    Thank you. I am in the process of ordering my update. I know that the reverse option in version 4.2 was very weak. I am hoping that 5.0 will be better.
    2005-10
    Allentown PA
    14
    Aturn is now up to v5.0. I went to an upgrade class about a year ago, and the reverse movements are very nice. It also helped that i had someone explain to me how a truck driver thinks doing a reverse movement as well.
    Rigby, Idaho
    106
    Quote Originally Posted by kspear
    Thank you for your input. I have ordered my copy of version 5. It should be here today. There will be a webcast training coming up in February.
  1. Turning Radius Software
    By Iceberg in forum Software
    Last Post: 2019-08-21, 10:44 PM
  2. Can't get radius dim as I want it
    By wolfgrrlone in forum AutoCAD General
    Last Post: 2012-06-13, 12:45 PM
  3. W-BM Radius
    By tiffany.amorgan in forum Dynamic Blocks - Technical
    Last Post: 2008-01-15, 07:34 PM
  4. Radius slabs turn pointy
    By rkc in forum ACA General
    Last Post: 2007-01-17, 05:34 PM
