When joining lines and arcs to a Pline using the PEDIT command (eg. centerline of a road), sometimes not all the entities get joined to the PLine.
Here's a trick to find out where EXACTLY the PEDIT command stopped joining....
First, change the physical color (ie. color ByEntity) of the PLINE that you will be using to have other entities joined to it.
Then, enter the PEDIT command and go through the normal routine of trying to join other entities.
When you are done with the PEDIT command, you should notice that al the entities that got joined are now the same ByEntity color of the original PLINE.
If there are other objects that did NOT get joined, you will see EXACTLY where those objects are, and thus will save you time fom trying to locate it.
